STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Resolved! STM32WB55CC BLE stack not initializing
Hello,I'm trying to implement BLE functionality on a custom board equipped with an STM32WB55CC using CubeMX.I managed to successfully (or so I think, the option bytes look good) install the BLE stack binary, but the device is not advertising. I mana...
Resolved! STM32WLE5 Module JOIN FAILED
Hi,I'm doing tests based on the LoRaWAN_AT_Slave. One of the modules often appears tMAC txTimeOut, resulting in JOIN FAILED. Same firmware downloaded, but some devices are working, is there any doubt? Is it a hardware problem? [14:47:35.933]发→◇AT+JOI...
ethan2 by Associate II
  • 1392 Views
Resolved! STM32WB55 BLE
Edit by ST Moderator: This post has been translated from Chinese to comply with the ST Community Terms and Conditions (§10.2). When I burned the Bluetooth protocol stack onto the new chip, my code was not executed efficiently and the Bluetooth broadc...
CHEN25 by Associate II
  • 1491 Views
Resolved! APS Layer configuration : Ack requirement
Hello,I'm trying to make an OnOff Switch emitter using zigbee on the STM32WB55 Nucleo Board. I started my project from the Zigbee_OnOff_Client_Distrib applications exemple.The receiver that I use is not made to send back APS ACK. Because of this I ad...
Nath by Associate
  • 1686 Views
Zigbee coordinator network management
We have a Zigbee network, working as a coordinator, and we want to know which devices are connected. In order to know which devices are connected, we use this code: while (ZbNwkGetIndex(zigbee_app_info.zb, ZB_NWK_NIB_ID_NeighborTable, &neighbor, size...
