2020-10-12 7:20 AM
Hi Everyone,
If you haven't noticed by now, X-CUBE-TOUCHGFX 4.15.0 is out, available from CubeMX 6.0+ and from st.com as a zip (Also installable through CubeMX).
Main features:
Here's the documentation for 4.15.0: https://support.touchgfx.com/
/Martin
2020-12-21 8:32 AM
CubeIDE has an update also, curious what the details are there.
2020-12-31 9:15 AM
someone else posted a link to the changelog, it is here: https://support.touchgfx.com/docs/miscellaneous/changelog
the download page still says 4.15, but the file you get is 4.16 , in the designer, the tooltip for the Gauge widget is wrong.
Installed 4.16, everything seems like its working ok
2021-01-04 12:39 AM
It's just bad UI - When you're selecting a version you're actually selecting an OLD version. So the default is 4.16.0 unless you specifically choose a version - in this case you can only choose old ones.
/Martin
