2019-10-02 12:47 AM
Hello everyone.
I want to show a picture from external SDRAM in 8bit mode using FMC with stm32f429zi discovery board.
As long as I use FMC in 16bit mode with 16-bit byte enabled, I can show a picture but as soon as I uncheck "16-bit byte enable", even in 16 bit mode, everything get ruined.
Thanks
2019-10-02 3:38 AM
Where do you uncheck that? What does it mean in terms of FMC registers' content? What does "even in 16-bit mode" mean?
Don't you exceed the memory's bandwith? Read AN4861.
