2025-08-19 2:25 AM - last edited on 2025-08-21 8:44 AM by Amel NASRI
I'm looking for a solution for regarding this simple problem:
This concerns the NemaGFX library for the GPU2D.
Using the latest NeoChromSDK_NEMAP_1.4.17, some functions have been replaced by new ones, in short:
Deprecated New
nema_vg_paint_set_stroke_width nema_vg_stroke_set_width
nema_vg_draw_ring_generic nema_vg_draw_circular_ring (not defined?)
We will find this part in the nema_vg.h header file:
nema_vg_draw_ring_generic: This function is deprecated use nema_vg_draw_circular_ring instead.
However, the problem is that nema_vg_draw_circular_ring seems undefined in any of the header files.
I reported the problem as follows:
Good morning Pavan,
This concerns NeoChromSDK_NEMAP_1.4.17
I have updated the libraries to the latest version of NeoChromSDK.
A few functions are deprecated:
Deprecated New
The problem is that the new function nema_vg_draw_circular_ring does not seem to exist.
I updated the libraries to this latest version of NeoChromSDK.
What did I do wrong?
Kind regards,
Jack.
I think the problem described is truly the simplest in the world.
But the next answer asked for a screenshot!
Edit by moderator to remove screenshot as it contains private data.
So I send a screenshot of that particular part of the nema_vg.h header file, explaining that the new function nema_vg_draw_circular_ring does not seem to exist:
In todays response, a FULL-PAGE screenshot is requested!
That would only add irrelevant information.
I am deeply disappointed with ST's support for this issue, as I don't think it's making any progress at all.
Perhaps the problem is being addressed to the wrong group?
Perhaps the problem should be forwarded to someone else?
Can anyone help?
Best regards,
Jack
2025-08-21 8:50 AM
Hi @Jack3 ,
Indeed the problem was shared with the wrong group who is trying to understand the issue (that should be out of their scope), trying to find a way to help.
I moved your question to TouchGFX forum, and I mention @Osman SOYKURT who can help to manage your case properly.
-Amel
2025-08-25 12:12 AM
Hi Amal,
do you please have the link to it, so I follow up?
Thank you very much!
2025-08-25 1:20 AM
Hi Jack,
It remains under the same current discussion.
Unfortunately, it might take some time to receive an answer as it is still the vacation period. If there is any urgency, please submit an OLS ticket.
-Amel
