2014-08-01 4:45 AM
Sir,
I want to interface camera module that gives throughput of 28Mbps, & I want to interface it to STM32F207. The same data is to be sent to wifi module using USB 2.0 by making STM32F207 as a host. For this I want to know the firmware size that would be & also would there be sufficient SRAM available for loading wifi drivers? Regards Aditya #dcmi-stm32f2072014-08-01 7:26 AM
Does the WiFi driver need to load into SRAM? What's you experience with this driver on other platforms you've used it on? What does it need there? Have you written many USB Host drivers?
2014-08-05 12:15 AM
Is STMF20 UVC compliant?
2014-08-05 4:50 AM
It's not a host example ST typically provides. The data rate you indicate suggests you'd need an external USB 2.0 HS PHY
If you don't have any experience writing USB host drivers, this probably isn't the platform to learn on.2014-08-05 11:49 PM
2014-08-07 11:03 PM
I need timing analysis of DVP DCMI to find rise time,fall time, setup time, hold time required for camera output to support the compatibility with STM32F207. Please give me the link of document. Regards Aditya,
2014-08-10 11:29 PM
I need timing analysis literature of DVP DCMI to find rise time,fall time, setup time, hold time required for camera output to support the compatibility with STM32F207. Please give me the link of document.
