STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
touchgfx - binary has debug info?
Hello, I was looking at the microcontroller binary of a project that I'm using the touchgfx library and something is getting my attention. There is a big part of the file that contains a lot of code information from the touchgfx library. I don't thin...
SGold by Associate II
  • 1286 Views
Inconsistent asset generation
I can correctly convert the assets from inside the Designer, either with "Run simulator" or "Generate code" (which I assume are identical, as far as converting assets goes).I selected "remap texts" from the config options in the Designer.Indeed, the ...
SZano by Associate III
  • 1295 Views
Simple Example for a Pick List
Does anyone have a simple example for a picklist? I tried making a custom contrainer for a "pick list item" then I used a scrollwheel container to make a list. But how do I edit the code to change the names of the items? I tried following the example...
MThom.2 by Associate II
  • 1685 Views
