STM32 MCUs Security
Resolved! RDP level2 isn't compatible with WRP
Hello,please I need a confirmation about RDP level2 and WRP combination on stm32g031 chip.Based on RM0444.Rev5 Table 19, if I use my own bootloader and I write-protect the flash sectors, I have to avoid activating RDP level2 or I'll loose the opportu...
S-.1 by Associate II
  • 3706 Views
Resetting an STM32H755 with secure area
I am building a secure bootloader on the STM32H755, but I've bricked a couple of boards now trying to get the secure areas working.I intended to use a "recovery" function on a button press to do a mass erase with protection removal. Then I can test e...
gpeh by Associate III
  • 8772 Views
  • 19 replies
  • 8 kudos
Resolved! configuration of the Tamper pins
Hi all,One small doubt on the tamper configuration, is it possible to configure both active and Passive tamper in the Same project/API, or  both should be in different project/API. why this doubt is as Seed is not required for Passive tamper, so does...
meghasb by Senior
  • 3658 Views
TPM maximum NV storage size
Hello As in the title, for my project I'd like to know exactly what is the maximum storage capability/size of the device NV memory.The TPM used is ST33TPHF2XI2C.I wasn't able to find anything in ST documentation (datasheet, application notes).Waiting...
edopeter by Associate
  • 1882 Views
AES in STM32F423
Hello  for allIn last days i was begin to implementation AES to work on stm32f423I am using example in NIST Special Publication 800-38A to take key-128 bit, input data that plain text , encryption and decryption data.but nothing seems to work , when ...
mick by Associate II
  • 1852 Views
Resolved! How to integrate SBSFU in STM32U585 series
Hello support team,Have a Nice day.I am working on STM32U585ZIT6 Controller and investigating SBSFU for firmware upgrading.I list our specifications for a custom bootloader below.Enable TrustZoneEnable Dual bankRun time firmware write in the second b...
Secure key storage using SAES engine
Hi, with MCU STM32U585QII6QTR we encrypted an AES key using SAES engine and stored it in Internal Flash in RDP Level 0 and then moved to RDP Level 1. When we decrypt the key that was encrypted in RDP Level 0 using SAES engine, we didn't get our origi...
Kishore2 by Associate
  • 1496 Views
