2025-10-17 8:36 AM
Hello Team,
I want to store encryption Key - 4 byte into Option Byte OR any other memory Except in-built Flash Memory.
Is it possible to write in Option Memory ?
If not what could be the other option ?
2025-10-28 9:11 AM
Note you should not accept your post as solution but the post that answered your question/solved your problem unless you posted the solution you found yourself.
Thank you.
2025-10-29 3:53 AM
Oh , Okay.
I was not aware about that.
Tell me if I can reverese it ?
2025-10-29 3:57 AM
@bsuthar wrote:
Oh , Okay.
That's OK now :)
