2025-02-16 11:42 PM
Hi All,
On a custom board we have notice weird behaviour with the watchdog timer.
Indeed sometimes on low temperature (closer to 0°C) the board is unable to restart normally on WDT reset.
On WDT reset, the scheduler restarts during few ticks and hangs.
Any ideas would be will be very appreciated.
2025-02-17 12:13 AM
I would check my oscillators first - are all running at correct frequency?
Than I would escalate to power supplies
An have a look at Watchdog registers
2025-02-17 12:22 AM
As mentioned, this sounds very much like a hardware issue.
Either external clock generation (quartz), or the power supply.
I suggest to check if and where your MCU has a MCO output.
Instrument your code, and watch MCO during such low-temperature restart events.
