2025-11-30 3:13 AM
I configured TIM1 as shown in the attached image:
Everything works as expected
I am controlling an inductive load which oscillates heavily after the PWM is turned off. I therefore decided to immediately short the low-side MOSFET (CH1N) to ground if a BREAK or BREAK2 signal is received. I set the Channel Idle State to SET. And the behavior of BREAK/BREAK2 changed.
As seen in the close-up::
A low state on BK2 does not set a high state on CH1N. Should BK1 and BK2 not be ORed?
2025-12-03 6:43 AM
Hi @PKurz.1 ,
first suggestion is not to reply on your own question. People actively looking for unanswered question will miss it. There's a break related AN4277, take a look if you can find an answer there.
My first impression from your screenshots is that you are perhaps having problems with dead time insertion.
Kind regards,
Jarda
2025-12-03 2:42 AM
any suggestions ?
2025-12-03 6:43 AM
Hi @PKurz.1 ,
Kind regards,
Jarda
