2023-02-22 4:06 PM
Using the IWDG within STM32L452 in its window mode.
At some point the application needs to freeze the IWDG module functionality, or as a minimum make it work as in non-window mode.
Is this possible? If yes, using which function?
Note the I couldn't locate a 'DeInit ' function for the IWDG firmware library.
2023-02-23 1:56 PM
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line. Should anyone have any similar questions, please feel free to open a Support case directly at your myST portal: https://st.com/ols
