2024-09-03 6:25 AM
I'm working on STM32H743BIT6, It is in production phase. During flashing the software, it is failed to configure LSE crystal with internal RTC enabled. out of 50 boards 2 board got failed.
During debug it is observed that the RTC clock configuration is getting failed.
Kindly support us for resolving the issue
Thank You
Anil Gayakwad
2024-09-03 6:48 AM
Not sure what do you mean by "During flashing the software, it is failed to configure LSE crystal with internal RTC enabled". ?
Do you mean that the RTC failed to be configured at your application startup? and what is the symptom? enable to write to a register or what?
