2015-11-29 11:41 PM
Hi all,
I'm trying to run the example Udp Echo Server with raw API from LwIP (included in the cube 1.9.0) on a STM32F4 discovery board, with a STM32F4DIS-BB extension board. Unfortunately the code doesn't seem to work. Basically, there is an infinite loop in the main function that (indirectly) calls the HAL_ETH_GetReceivedFrame in stm32f4xx_hal_eth.c. However, there is a test at the beginning of this function that checks whether the segment is not owned by DMA and that always fails. As a result, this function always returns an error and no frame ever gets read. I didn't modify the sample code, so I don't really see why this doesn't work. Does anyone have an idea? Thanks in advance2016-01-06 2:03 AM
I have been facing the same issue. I was trying to interface a LAN via ethernet on stm32f4dis-bb board using stm32cubeMX. attached is the configuration file. I have also tried from this forum
/public/STe2ecommunities/mcu/Lists/STM32Java/DispForm.aspx?ID=444&RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/STM32F4DIS-BB%20%2b%20ETH%20%2b%20CubeMX&Source=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder%3Dhttps%253a%252f%252fmy%252est%252ecom%252fpublic%252fSTe2ecommunities%252fmcu%252fLists%252fSTM32Java%252fSTM32F4DIS%252dBB%2520%252b%2520ETH%2520%252b%2520CubeMX%26FolderCTID%3D0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21%26currentviews%3D1720
Try this maybe you find out something, but its not working for me. If you get something please post in this thread. ST team please help us to develop this from the scratch using stm32cubeMX or update a library for MX. ________________ Attachments : test3.ioc : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzn4&d=%2Fa%2F0X0000000bPk%2FlQt6_7n0WIFdebRWRp_NN7r6nL5a9iq4VBujMJFS_GM&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
