2015-07-27 1:54 AM
i use a STM32F439 controller with 32Mbyte external SDRAM. I would like to configure some settings with STCube. There is a tab FMC with a sub-tab SDRAM1. When i select Data: 32 bits i can choose either Byte enable : disable or Byte enable : 32-Bit byte enable. Do you know if i should enable it ? For what exactly is it ?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
