2019-05-20 10:56 AM
Hi GuysI I am a beginner and appreciate any help!
I need to measure with this microcontroller power consumption on SonyPlayStation, Xbox and Nintendo.
Could someone give me a possible solution way/recommendations, what should I do, and how could I do it ?
I'll be working on MacOS, so which development environment would be the best ?
Thanks in advance!
2019-05-20 3:47 PM
Isn't there a jumper for the microcontroller side. Board level might be more complicated. Perhaps mod a USB cable so you can run the 5V through a multimeter so you can measure the current with that.
2019-05-21 3:41 AM
There is a jumper, but is there any tutorial online or scripts or whatsoever with examples that I can read or watch how it should work?
