2021-06-17 8:57 AM
I used the:
"STM32H743I-EVAL\Examples\FDCAN\FDCAN_Classic_Frame_Networking" example on my board.
I can send and receive Standard ID message to and from my CAN BUS Analyser, but can only send Extended messages. Cannot receive them. I have attached the init code for both Standard and Extended.
2021-06-23 9:57 PM
On line 42 of your code, you define ExtFiltersNbr to 0. Change it to 1 so you can actually assign the extended filter to catch the specific message (you define the filter on line 67)
Best regards,
2021-06-21 3:58 AM
I tried to create a project in loopback mode based on STM32H743I-EVAL\Examples\FDCAN\FDCAN_Loopback example.
The attached example runs on NUCLEO-H743 board and it sends & receives standard and Extended frames. You can port it to STM32H743I-EVAL board.
Hope this will help you.
STM32
2021-06-23 9:57 PM
Best regards,
2021-06-24 7:03 AM
I haven't had a chance to update but you are exactly right. One of my field engineers from Arrow pointed that out and suddenly everything worked fine.
Thanks for responding.
