2021-06-09 1:52 AM
I saw that Hyperbus protocol with differential clock (1.8V) is not available on STM3L4R5ZIT6P, but Hyperbus protocol with single-ended clock(3.3V) is.
My question is : is the Nucleo -L4R5ZI-P board supporting Hyperbus protocol with single-ended clock because I haven’t seen any reference to it in NUCLEO’s documentation?
Thanks
2021-06-09 5:17 AM
The NUCLEO provide little in the way of on board hardware. You should check the data manual for pin usages, and reference manual for the chip level support. You'll need to code drivers, or find some to back port.
