2025-09-15 8:23 AM
Trying to set Option Bytes over USB with DFU protocol to STM32G0C1VET6's embedded System Bootloader results in a LIBUSB Pipe Error.
Steps to reproduce with details captured further below:
I suspect the problem is with the interface descriptors advertised by the embedded System Bootloader. Both `dfu-util -l` and `lsusb -vvv` show the same 512KB 0x0800000 User Flash block for all 3 alt settings. Comparing my output to other micros suggest alt=0 should be internal flash, alt=1 should be Option Bytes (@ 0x1FFF7800) and alt=2 should be OTP (@ 0x1FFF7000). Per rm0444 page 61. This means it looks like the embedded system bootloader only allows the writing of its main user flash since that's the only address range advertised in the interface descriptors and NOT any Option Bytes or OTP.
Is it possible to write Option Bytes and OTP over USB DFU to this micro?
Thanks!
$ dfu-util -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Found DFU: [0483:df11] ver=0200, devnum=6, cfg=1, intf=0, path="1-1", alt=2, name="@Internal Flash /0x08000000/256*02Kg", serial="<REDACTED>"
Found DFU: [0483:df11] ver=0200, devnum=6, cfg=1, intf=0, path="1-1", alt=1, name="@Internal Flash /0x08000000/256*02Kg", serial="<REDACTED>"
Found DFU: [0483:df11] ver=0200, devnum=6, cfg=1, intf=0, path="1-1", alt=0, name="@Internal Flash /0x08000000/256*02Kg", serial="<REDACTED>"
$ lsusb -vvv
Bus 001 Device 006: ID 0483:df11 STMicroelectronics STM Device in DFU Mode
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0483 STMicroelectronics
idProduct 0xdf11 STM Device in DFU Mode
bcdDevice 2.00
iManufacturer 1 STMicroelectronics
iProduct 2 DFU in FS Mode
iSerial 3 <REDACTED>
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x002d
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 2 DFU in FS Mode
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 2
iInterface 6 @Internal Flash /0x08000000/256*02Kg
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 0
iInterface 7 @Internal Flash /0x08000000/256*02Kg
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 2
bNumEndpoints 0
iInterface 8 @Internal Flash /0x08000000/256*02Kg
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 11
Will Detach
Manifestation Intolerant
Upload Supported
Download Supported
wDetachTimeout 255 milliseconds
wTransferSize 1024 bytes
bcdDFUVersion 1.1a
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
For dfu-util try reading SEC_SIZE Option Byte bank:
$ dfu-util -d 0483:df11 -a 1 -s 0x1fff7870 -U option_bytes.bin -Z 4
dfu-util 0.9
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 1024
DfuSe interface name: "Internal Flash "
dfu-util: Page at 0x1fff7870 is not readable
STM32CubeProgrammer
15:07:53:868 : USB speed : Full Speed (12MBit/s)
15:07:53:868 : Manuf. ID : STMicroelectronics
15:07:53:868 : Product ID : DFU in FS Mode
15:07:53:868 : SN : <REDACTED>
15:07:53:868 : DFU protocol: 1.1
15:07:53:868 : Board : --
15:07:53:868 : Device ID : 0x0467
15:07:53:868 : setting the address pointer to address: 0x08000000
15:07:53:869 : setting the address pointer to address: 0x08000000
15:07:53:869 : setting the address pointer to address: 0x1fff7800
15:07:53:869 : receiving packet nbr: 0
15:07:53:869 : sending an abort request
15:07:53:869 : UpLoading data
15:07:53:870 : sending an abort request
15:07:53:870 : setting the address pointer to address: 0x1fff7800
15:07:53:870 : receiving packet nbr: 0
15:07:53:870 : UpLoading data
15:07:53:871 : setting the address pointer to address: 0x1fff75e0
15:07:53:871 : receiving packet nbr: 0
15:07:53:871 : sending an abort request
15:07:53:871 : UpLoading data
15:07:53:871 : Database: Config 1 is active.
15:07:53:871 : setting the address pointer to address: 0x08000000
15:07:54:013 : setting the address pointer to address: 0x08000000
15:07:54:014 : UPLOADING OPTION BYTES DATA ...
15:07:54:014 : Bank : 0x00
15:07:54:014 : Address : 0x1fff7800
15:07:54:014 : Size : 68 Bytes
15:07:54:014 : setting the address pointer to address: 0x1fff7800
15:07:54:014 : receiving packet nbr: 0
15:07:54:014 : sending an abort request
15:07:54:015 : UpLoading data
15:07:54:015 : Bank : 0x01
15:07:54:015 : Address : 0x1fff7870
15:07:54:015 : Size : 4 Bytes
15:07:54:015 : sending an abort request
15:07:54:015 : setting the address pointer to address: 0x1fff7870
15:07:54:016 : receiving packet nbr: 0
15:07:54:016 : sending an abort request
15:07:54:016 : UpLoading data
15:07:54:016 : UPLOADING ...
15:07:54:016 : Size : 1024 Bytes
15:07:54:016 : Address : 0x8000000
15:07:54:016 : Read progress:
15:07:54:017 : sending an abort request
15:07:54:017 : setting the address pointer to address: 0x08000000
15:07:54:017 : receiving packet nbr: 0
15:07:54:036 : sending an abort request
15:07:54:037 : UpLoading data
15:07:54:037 : Data read successfully
15:07:54:037 : Time elapsed during the read operation is: 00:00:00.007
15:08:10:086 : Option byte command : -ob SEC_SIZE=0x1
15:08:10:089 : qCmd : -ob SEC_SIZE=0x1
15:08:10:089 : PROGRAMMING OPTION BYTES AREA ...
15:08:10:090 : sending an abort request
15:08:10:090 : setting the address pointer to address: 0x1fff7800
15:08:10:090 : receiving packet nbr: 0
15:08:10:091 : sending an abort request
15:08:10:092 : UpLoading data
15:08:10:093 : sending an abort request
15:08:10:093 : setting the address pointer to address: 0x1fff7800
15:08:10:094 : receiving packet nbr: 0
15:08:10:094 : sending an abort request
15:08:10:095 : UpLoading data
15:08:10:096 : sending an abort request
15:08:10:097 : setting the address pointer to address: 0x1fff75e0
15:08:10:098 : receiving packet nbr: 0
15:08:10:098 : sending an abort request
15:08:10:099 : UpLoading data
15:08:10:100 : Database: Config 1 is active.
15:08:10:100 : Bank : 0x01
15:08:10:100 : Address : 0x1fff7870
15:08:10:100 : Size : 4 Bytes
15:08:10:102 : sending an abort request
15:08:10:103 : setting the address pointer to address: 0x1fff7870
15:08:10:103 : sending packet nbr: 0
15:08:10:103 : downloading data
15:08:10:136 : libusb get status error [-9] : LIBUSB_ERROR_PIPE
15:08:10:136 : An error occured while downloading data
15:08:10:136 : Reconnecting...
15:08:20:134 : Unable to reconnect the target device: time out expired
15:08:20:134 : Uunable to reconnect the target device: time out expired
15:08:20:134 : Error: Downloading Option Bytes Data failed
15:08:20:139 : UPLOADING OPTION BYTES DATA ...
15:08:20:139 : Bank : 0x00
15:08:20:139 : Address : 0x1fff7800
15:08:20:139 : Size : 68 Bytes
15:08:20:140 : Error: Uploading Option Bytes bank: 0 failed
15:08:20:148 : Database: Config 6 is active.
15:08:20:148 : Time elapsed during option Bytes configuration: 00:00:10.047
15:08:20:272 : Warning: Connection to device 0x467 is lost
15:08:20:305 : Disconnected from device.
$ STM32_Programmer_CLI -vb 2 -c port=usb1 -ob SEC_SIZE=0x10
STM32CubeProgrammer v2.17.0
SN : <REDACTED>
DFU protocol: 1.1
Board : --
Device ID : 0x0467
UpLoading data
UpLoading data
UpLoading data
UpLoading data
UpLoading data
UpLoading data
Device name : STM32G0B0xx/B1xx/C1xx
Flash size : 512 KBytes (default)
Device type : MCU
Revision ID : --
Device CPU : Cortex-M0+
Bank : 0x00
UpLoading data
Bank : 0x01
UpLoading data
UpLoading data
UpLoading data
UpLoading data
Bank : 0x01
downloading data
Reconnecting...
Reconnecting...
Bank : 0x00
Time elapsed during option Bytes configuration: 00:00:10.042
2025-10-31 10:04 AM
I've successfully set the SEC_SIZE Option Byte on a STM32G0C1E-EV over USB talking to the ST Embedded Bootloader. The fix was to apply a database patch provided by ST which enabled version 2.20.0 of both the STM32CubeProgrammer (GUI) and STM32_Programmer_CLI (CLI) tools to work. I'm unsure if this allows full Option Byte and OTP access but it did allow SEC_SIZE to be written. I suspect ST will apply the database patch in a future STM32CubeProgrammer update.
2025-09-17 2:24 AM - edited 2025-09-17 2:59 AM
Hi @bitkicker
Before proceeding further, could you please confirm a couple of points?
option_bytes.bin
2025-09-17 8:31 AM
Hey @FBL ,
STM32_Programmer_CLI -c port=JLINK mode=hotplug -ob SEC_SIZE=0x1$ STM32_Programmer_CLI -c port=JLINK -d test.bin 0x08060800
Connecting to J-Link Probe
Device=Cortex-M0
Device ID : 0x467
Voltage : 3.29V
Memory Programming ...
Opening and parsing file: test.bin
File : test.bin
Address : 0x08060800
Erasing memory corresponding to segment 0:
Erasing internal memory sector 193
Download in Progress:
[==================================================] 100%
File download complete
Time elapsed during download operation: 00:00:00.066
$ STM32_Programmer_CLI -c port=usb1 -d test.bin 0x08060800
SN : <REDACTED>
DFU protocol: 1.1
Board : --
Device ID : 0x0467
Device type : MCU
Revision ID : --
File : test.bin
erasing sector 0193 @: 0x08060800 done
Time elapsed during download operation: 00:00:00.031
$ dfu-util -l
dfu-util 0.9
Found DFU: [0483:df11] ver=0200, devnum=21, cfg=1, intf=0, path="1-1", alt=2, name="@Internal Flash /0x08000000/256*02Kg", serial="<REDACTED>"
Found DFU: [0483:df11] ver=0200, devnum=21, cfg=1, intf=0, path="1-1", alt=1, name="@Internal Flash /0x08000000/256*02Kg", serial="<REDACTED>"
Found DFU: [0483:df11] ver=0200, devnum=21, cfg=1, intf=0, path="1-1", alt=0, name="@Internal Flash /0x08000000/256*02Kg", serial="<REDACTED>"$ dfu-util -d 0483:df11 -a 1 -s 0x1fff7870 -U option_bytes.bin -Z 4
dfu-util 0.9
ID 0483:df11
Determining device status: state = dfuDNLOAD-IDLE, status = 0
aborting previous incomplete transfer
dfuIDLE, continuing
$ ll option_bytes.bin
-rw-r--r-- 1 vscode vscode 0 Sep 17 15:18 option_bytes.bin
2025-09-18 11:38 AM
Could how I enter the embedded system bootloader affect the interface description it allows over USB DFU?
My BOOT0 pin is a little difficult to get to. So I've been fully erasing User Flash via SWD. Then disconnecting that and power-cycling the micro to load the embedded system bootloader via USB HID.
2025-09-19 8:43 AM
I've replicated the issue on another board and attempted to use the Serial COM Port to the embedded bootloader which fails:
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 043: ID 0483:df11 STMicroelectronics STM Device in DFU Mode
Bus 001 Device 042: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 037: ID 1366:1020 SEGGER J-Link Pro
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ STM32_Programmer_CLI -vb 2 -c port=/dev/ttyUSB0 -ob displ
Serial Port /dev/ttyUSB0 is successfully opened.
Port configuration: parity = even, baudrate = 115200, data-bit = 8,
stop-bit = 1.0, flow-control = off
Timeout error occured while waiting for acknowledgement.
No response from target received
Retrying UART init connection...
Error: Activating device: KO. Please, verify the boot mode configuration and check the serial port configuration. Reset your device then try again...
2025-10-31 10:04 AM
