2025-10-29 12:00 PM - edited 2025-10-29 12:03 PM
Hello ST Community,
I'm working on implementing USB Audio Class 2.0 with both speaker and microphone functionality on STM32WBA65 using USBX middleware.
Request for Example: Are there any complete working examples of USBX Audio Class 2.0 with microphone streaming (USB Audio input) for STM32WBA series? The existing examples I've found only demonstrate speaker/playback functionality.
Current Issue:
I have implemented a USB Audio Class 2.0 device configured for both speaker and microphone, but only the speaker is working.
The device descriptor is correctly recognized by Windows 11:
Problem: The microphone stream never initializes. Specifically:
Configuration:
This suggests the USB descriptor is being accepted by Windows, but something prevents the microphone stream from being activated by the host.
Has anyone encountered this issue? Any insights on what might cause Windows to recognize but not activate a USB Audio input stream?
This is the descriptor read by USB descriptor dumper:
Information for device STM32 AUDIO20 STREAMING-L (VID=0x0483 PID=0x5740):
Connection Information:
Device current bus speed: HighSpeed
Device supports USB 1.1 specification
Device supports USB 2.0 specification
Device address: 0x0022
Current configuration value: 0x01
Number of open pipes: 0
Device Descriptor:
0x12 bLength
0x01 bDescriptorType
0x0200 bcdUSB
0x00 bDeviceClass
0x00 bDeviceSubClass
0x00 bDeviceProtocol
0x40 bMaxPacketSize0 (64 bytes)
0x0483 idVendor
0x5740 idProduct
0x0200 bcdDevice
0x01 iManufacturer "STMicroelectronics"
0x02 iProduct "STM32 AUDIO20 STREAMING-L"
0x03 iSerialNumber "CDC_ACM_AUDIO_001_L"
0x01 bNumConfigurations
Device Qualifier Descriptor:
0x0A bLength
0x06 bDescriptorType
0x0200 bcdUSB
0x00 bDeviceClass
0x00 bReserved
Configuration Descriptor:
0x09 bLength
0x02 bDescriptorType
0x00FB wTotalLength (251 bytes)
0x03 bNumInterfaces
0x01 bConfigurationValue
0x00 iConfiguration
0xC0 bmAttributes (Self-powered Device)
0x32 bMaxPower (100 mA)
Interface Association Descriptor:
0x08 bLength
0x0B bDescriptorType
0x00 bFirstInterface
0x03 bInterfaceCount
0x01 bFunctionClass (Audio Device Class)
0x00 bFunctionSubClass
0x20 bFunctionProtocol (Audio Protocol IP version 2.00)
0x00 iFunction
Interface Descriptor:
0x09 bLength
0x04 bDescriptorType
0x00 bInterfaceNumber
0x00 bAlternateSetting
0x00 bNumEndPoints
0x01 bInterfaceClass (Audio Device Class)
0x01 bInterfaceSubClass (Audio Control Interface)
0x20 bInterfaceProtocol (Audio Protocol IP version 2.00)
0x00 iInterface
AC Interface Header Descriptor:
0x09 bLength
0x24 bDescriptorType
0x01 bDescriptorSubtype
0x0200 bcdADC
0x03 bCategory (MICROPHONE)
0x0073 wTotalLength (115 bytes)
0x00 bmControls
AC Clock Source Descriptor:
0x08 bLength
0x0A bDescriptorSubtype
0x18 bClockID
0x01 bmAttributes
0x01 bmControls
Clock Frequency Control - read only
0x00 bAssocTerminal
0x00 iClockSource
AC Input Terminal Descriptor:
0x11 bLength
0x02 bDescriptorSubtype
0x12 bTerminalID
0x0101 wTerminalType (USB Streaming)
0x00 bAssocTerminal
0x18 bCSourceID
0x02 bNrChannels (2 channels)
0x00000003 bmChannelConfig
0x00 iChannelNames
0x00 bmControls
0x00 iTerminal
AC Feature Unit Descriptor:
0x12 bLength
0x06 bDescriptorSubtype
0x16 bUnitID
0x12 bSourceID
0x0000000F bmaControls(0)
Mute Control - host programmable
Volume Control - host programmable
0x00000000 bmaControls(1)
0x00000000 bmaControls(2)
0x00 iFeature
AC Output Terminal Descriptor:
0x0C bLength
0x03 bDescriptorSubtype
0x14 bTerminalID
0x0301 wTerminalType (Speaker)
0x00 bAssocTerminal
0x16 bSourceID
0x18 bCSourceID
0x0000 bmControls
0x00 iTerminal
0x08 bLength
0x19 bClockID
0x01 bmAttributes
0x01 bmControls
0x00 bAssocTerminal
0x00 iClockSource
0x11 bLength
0x20 bTerminalID
0x0201 wTerminalType (Microphone)
0x00 bAssocTerminal
0x19 bCSourceID
0x01 bNrChannels (1 channels)
0x00000001 bmChannelConfig
0x00 iChannelNames
0x00 bmControls
0x00 iTerminal
0x0E bLength
0x22 bUnitID
0x20 bSourceID
0x00 iFeature
0x0C bLength
0x24 bTerminalID
0x00 bAssocTerminal
0x22 bSourceID
0x19 bCSourceID
0x0000 bmControls
0x00 iTerminal
0x09 bLength
0x01 bInterfaceNumber
0x00 bNumEndPoints
0x02 bInterfaceSubClass (Audio Streaming Interface)
0x00 iInterface
0x09 bLength
0x01 bAlternateSetting
0x01 bNumEndPoints
0x00 iInterface
AS Interface Descriptor:
0x10 bLength
0x12 bTerminalLink
0x00 bmControls
0x01 bFormatType (FORMAT_TYPE_1)
0x00000001 bmFormats
PCM
0x00 iChannelNames
AS Format Type 1 Descriptor:
0x06 bLength
0x02 bSubslotSize
0x10 bBitResolution (16 bits per sample)
Endpoint Descriptor:
0x07 bLength
0x05 bDescriptorType
0x03 bEndpointAddress (OUT endpoint 3)
0x01 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Data)
0x001C wMaxPacketSize (1 x 28 bytes)
0x01 bInterval (1 microframes)
AS Isochronous Data Endpoint Descriptor:
0x08 bLength
0x25 bDescriptorType
0x00 bmAttributes
0x00 bmControls
0x00 bLockDelayUnits (undefined)
0x0000 wLockDelay
0x09 bLength
0x02 bInterfaceNumber
0x00 bNumEndPoints
0x00 iInterface
0x09 bLength
0x01 bNumEndPoints
0x00 iInterface
0x10 bLength
0x24 bTerminalLink
0x00 bmControls
PCM
0x00 iChannelNames
0x06 bLength
0x02 bSubslotSize
0x07 bLength
0x84 bEndpointAddress (IN endpoint 4)
0x0D bmAttributes (Transfer: Isochronous / Synch: Synchronous / Usage: Data)
0x000C wMaxPacketSize (1 x 12 bytes)
0x08 bLength
0x00 bmAttributes
0x00 bmControls
0x0000 wLockDelay
Other Speed Configuration Descriptor:
0x09 bLength
0x07 bDescriptorType
0x03 bNumInterfaces
0x00 iConfiguration
0x08 bLength
0x00 iFunction
0x09 bLength
0x00 bNumEndPoints
0x00 iInterface
0x09 bLength
0x0200 bcdADC
0x00 bmControls
0x08 bLength
0x18 bClockID
0x01 bmAttributes
0x01 bmControls
0x00 bAssocTerminal
0x00 iClockSource
0x11 bLength
0x12 bTerminalID
0x00 bAssocTerminal
0x18 bCSourceID
0x00 iChannelNames
0x00 bmControls
0x00 iTerminal
0x12 bLength
0x16 bUnitID
0x12 bSourceID
0x00 iFeature
0x0C bLength
0x14 bTerminalID
0x00 bAssocTerminal
0x16 bSourceID
0x18 bCSourceID
0x0000 bmControls
0x00 iTerminal
0x08 bLength
0x19 bClockID
0x01 bmAttributes
0x01 bmControls
0x00 bAssocTerminal
0x00 iClockSource
0x11 bLength
0x20 bTerminalID
0x00 bAssocTerminal
0x19 bCSourceID
0x00 iChannelNames
0x00 bmControls
0x00 iTerminal
0x0E bLength
0x22 bUnitID
0x20 bSourceID
0x00 iFeature
0x0C bLength
0x24 bTerminalID
0x00 bAssocTerminal
0x22 bSourceID
0x19 bCSourceID
0x0000 bmControls
0x00 iTerminal
0x09 bLength
0x00 bNumEndPoints
0x00 iInterface
0x09 bLength
0x01 bNumEndPoints
0x00 iInterface
0x10 bLength
0x12 bTerminalLink
0x00 bmControls
PCM
0x00 iChannelNames
0x06 bLength
0x02 bSubslotSize
0x07 bLength
0x00C4 wMaxPacketSize (1 x 196 bytes)
0x01 bInterval (1 frames)
0x08 bLength
0x00 bmAttributes
0x00 bmControls
0x0000 wLockDelay
0x09 bLength
0x00 bNumEndPoints
0x00 iInterface
0x09 bLength
0x01 bNumEndPoints
0x00 iInterface
0x10 bLength
0x24 bTerminalLink
0x00 bmControls
PCM
0x00 iChannelNames
0x06 bLength
0x02 bSubslotSize
0x07 bLength
0x0060 wMaxPacketSize (1 x 96 bytes)
0x08 bLength
0x00 bmAttributes
0x00 bmControls
0x0000 wLockDelay
Microsoft OS Descriptor is not available. Error code: 0x0000001F
String Descriptor Table
Index LANGID String
0x00 0x0000 0x0409
0x01 0x0409 "STMicroelectronics"
0x02 0x0409 "STM32 AUDIO20 STREAMING-L"
0x03 0x0409 "CDC_ACM_AUDIO_001_L"
Connection path for device:
Controladora de host USB genérico compatible con xHCI
Root Hub
Concentrador USB genérico
STM32 AUDIO20 STREAMING-L (VID=0x0483 PID=0x5740) Port: 2
Running on: Windows 10 or greater (Build Version 19045)
Brought to you by TDD v2.19.0, Dec 5 2023, 12:08:38
Thanks in advance for any help!
2025-10-30 3:45 AM - edited 2025-10-30 3:46 AM
> Unfortunately, as of now, we don't have direct examples for STM32WBA. Indeed, the existing examples only support speaker/playback. However, by using the X CUBE AUDIO Kit, you can find examples supporting microphone for different stacks including usbx tested on STM32H573I-DK, STM32H735G-DK, STM32H7S78-DK, and STM32N6570-DK Discovery kits.
2025-10-30 4:53 AM
Thank you for your response and the suggestion to check the X-CUBE-AUDIO package.
I have downloaded and reviewed the X-CUBE-AUDIO package, but I'm unable to find any USBX-based microphone streaming examples. Specifically:
Could you please clarify which specific project within the X-CUBE-AUDIO package contains the USBX microphone streaming implementation? Or perhaps provide the exact path to the relevant example?
If there are alternative resources or documentation that demonstrate USBX-based USB Audio input streaming, I would greatly appreciate any guidance you can provide.
The core issue remains: while my USB Audio Class 2.0 device is correctly recognized by Windows (both speaker and microphone appear in device lists), the microphone stream callback (USBD_AUDIO_RecordStreamChange) is never invoked, even when applications attempt to access the microphone.
Thank you for your continued support.
Best regards,
Hugo
2025-10-31 8:00 AM
Your request is forwarded to development team! Would you please provide more details about USBD_AUDIO_RecordStreamChange() in a github link or attach your project?
