STM32U575I-EV DCMI OV5640, maximize resolution for JPEGs
For the onboard OV5640 camera module that comes with the STM32U575I-EV, I would like to know how to get several of the largest resolutions for my JPEGs. I noticed the 2592x1944 that the OV5640 datasheet lists, but I'm also interested in whether other...
STM32U575I-EV FileX writes seem slow
The example project I'm basing most of my code off of is from the STM32CubeU5 MCU package  v1.4.0 (Projects\STM32U575I-EV\Applications\FileX\Fx_uSD_File_Edit). I'm looking to eventually apply this code to my primary project that saves JPEGs from a ca...
Resolved! Poor ADC quality on some Nucelo boards
Hi everyone :)I need your help. I am currently writing my masther thesis and I need robust and not noisy ADC read. I am using Nucleo board in my project so I hope hardware should have no effect in my case. The problem is ADC quality. I've tested thre...
KubaPy by Associate II
  • 3563 Views
STM32F469I-DISCO NEW LCD Driver Missing NT35510
About a month ago (April 2021) I purchased STM32F469I-Disco from mouser.de here in Germany, my first discovery board with display. Things went fishy from day 1, but only after more than 2 weeks of black screen I realized: my disco has a different scr...
ilyus by Senior II
  • 7163 Views
C data - 1000.0f
hi I would like to know what does the f means in both 1000.0f and 2000.f ? anyone can kindly advise? ScalingFactor = 1000.0f/32768.0f; ScalingFactor = 2000.0f/32768.0f;
How to read the Nand Flash in memory map mode?
Hi there,I wrote some data to the Nand Flash which is extended by FMC.The address of Nand Flash is 0x70000000 in STM32F429BIT6.I can read the Nand Flash data by HAL_NAND_Read_Page_8b() correctly.But when I access the data by memory map mode, the data...
Junde by Senior III
  • 1402 Views
Resolved! This Software is not availabale for download
No download is possible since a week on your website.I'd like to download stm32cubeMx and motor workbench. ISP: Swisscom AGCity: ZurichRegion: ZurichCountry: Switzerland Please fix that. I already lost one week.
Youni by Associate II
  • 4301 Views
  • 4 kudos
SPI communication STM32H7B3I-DK
Hello everyone!I am working on a project and using STM32H7B3I-DK board. I am facing issues with SPI communication. I am using simple code: while (1)  {    HAL_SPI_TransmitReceive(&hspi2, tx_data, rx_data, strlen(tx_data), HAL_MAX_DELAY); // Send AT c...
User1340 by Associate II
  • 1393 Views
Generating a Simple Boost PWM using stm32F103C8T6
I'm working on a Simple Boost PWM at 10KHz switching frequency for my Quasi Z source inverter. My requirements: Two PWM channels should generate complementary sine pwm when the shoot through condition is not satisfied. And the two channels should be ...
