Resolved! Wrong message ID sent on FDCAN
I am using the FDCAN module on STM32H753 to send messages. The message ID is always the same: 0x7DF. So I create a static Tx header:  static FDCAN_TxHeaderTypeDef txHeader = { .Identifier = 0x07DF, .IdType = FDCAN_STANDARD_ID, .TxFrameType = FDCAN_DA...
MZadn.1 by Associate II
  • 3436 Views
Issue to generate an alarm interupt on STM32C031
Hi,I try to configure a STM32C031K6 to generate an interupt every seconds using RTC Alarm A (RTC clocked by 32.768KHz crystal).I am working on STM32Cube IDE 1.15.1. First issue was that the device configuration tool does not generate any code regardi...
mjacquin by Associate
  • 1157 Views
STM32CubeMX Mac updater does not work
Hi,whenever I try to run the CubeMX updater on MacOS, using sudo, the update will fail with:" Updater cannot write on Software Folder. It's probably due to a bad Acces Privilege."I tried to give everyone, admin and me the right to read and write the ...
Resolved! Cannot get One-Pulse mode working
I know this might be a pretty basic thing to have issues with, but after banging my head against the wall on this for days, your snark-free assistance would be greatly appreciated.I am using a B-L072Z-LRWAN1 and trying to get timer 2 channel 1 to pro...
Resolved! NUCLEO-H563ZI_OEMiROT_Boot Example
Hi,I'm trying to integrate MCUBoot into an existing STM32CubeIDE project. As I wasn't sure where to start, I've found an example in STM32CubeIDE for NUCLEO-H563ZI.After generating the project, I've tried building it but I've got errors related to mis...
mjurjevic by Associate II
  • 5392 Views
Resolved! B-CAMS-OMV Camera Module
 Is my camera module working fine (all 3 LEDs light up)? What is camera continuous mode? Anyone have any information regarding this? I am working with the model zoo image classification project, and facing issue, after troubleshooting by blinking LED...
chew by Associate III
  • 4805 Views
Resolved! Seeking information on real-world PSSI performance
Hello All, I'd be glad to hear from someone who has used PSSI in a high-bandwidth application. I'm interestedin hard numbers on sustained throughput with/without flow-control. My intended application is to interface some member of the STM32 product l...
