RTC calibration
Posted on March 29, 2012 at 07:42Hi all,I wanted to know is there any software workaround to compensate for negative ppm values.I am using STM32F100V8 controller. According to the rtc digital calibration manual(attached) you can only subtract the cy...
Boring problems with ST LINK on STM32LVDISCOVER
Posted on April 04, 2012 at 17:17Hi folks,I have big problems with connecting to ST LINK integrated on ST discovery kit. I already install all utilities, driver updates (V2) and  test all tips and trick posted in forum, but the result is same...''Ca...
Register or Standard Peripheral Library
Posted on March 31, 2012 at 17:58Hello, I am new to this forum. Is there anyone who does not use Standard Peripheral Library for programin STM32F4 ? I'm don't like SPL and and programmed using registers for set the uC. I greet
we by Associate II
  • 1799 Views
Backlight Driver STLD41 producing disturbance on TFT
Posted on April 04, 2012 at 14:08Hello I am using STLD41 as backlight driver for 5.7''controllerless TFT. Whenever STLD41 gets on it produces lines on TFT & display gets disturbed.If i give backlight power seperately from power supply Display works ...
APB1|2 Peripheral Reset Registers
Posted on April 04, 2012 at 15:44The reference manuals don't really define what these registers do (at least RM0041).   I assume that toggling one of these bits resets the corresponding peripheral to its initial state.  That seems to be confirmed by...
Getting Started, MCU plays dead ?
Posted on March 05, 2012 at 03:33Hello, I am trying to get started with STM32 microcontrollers. I have a STM32F103RBT6 on a development board and I am using the gcc toolchain (target arm-elf, flags -s -Os -mthumb -mcpu=cortex-m3). The sample code I...
Getting started (progamming STM32 in C++)
Posted on March 19, 2012 at 10:07Hi, I've started a job where we use STM32 microcontrollers, programmed in C++ developed in Eclipse. I'm an electronics engineer with a solid understanding of microcontrollers (however my experience is with PIC and AD...
colm by Associate
  • 2082 Views
ethernet (UDP and TFTP)
Posted on March 30, 2012 at 16:19 Hi everybody, I want to make an Ethernet connection between the stm32f4 discovery board and my computer. I use a DP83848 Ethernet Board ( http://www.wvshare.com/product/DP83848-Ethernet-Board...
New F0-Discovery board with 'F051 Cortex-M0 report
Posted on April 01, 2012 at 20:03Grrrrr!!  I just wrote a long post about the new F0-Discovery board, and the forum software threw it away. Rather than re-write a thoughtful post, I'll do what the crappy forum software encourages me to do and write ...
donald2 by Associate II
  • 1734 Views
