STM32VLDISCOVERY - connection problem
Posted on November 10, 2013 at 23:45I have STM32VLDISCOVERY board and it works fine till now.Suddenly I have no more possibility to connect with target from STM32 ST-LINK utility. Following message appears after click to the button �connect to the t...
dlenarcic by Associate II
  • 1412 Views
Problems with Debug on STM32F4 discovery
Posted on November 09, 2013 at 21:11 Hi, I bought a development board STM32F4 discovery. I wanted to try the debug and I modified the example ADC3_DMA in STM32F4-Discovery_FW_V1.1.0 in this mode: but the program does not sto...
luca by Associate II
  • 3506 Views
STM32 software development tools (IDE)
Posted on September 28, 2013 at 17:01 .ExternalClass21148C261BC94D0298DAC9130DFEF74C P {margin-bottom:0.21cm;} .ExternalClass21148C261BC94D0298DAC9130DFEF74C A:link {;} Hi, I have ordered http://dx.com/p/stm32f103rbt6-minimum-system-development...
martin159 by Associate II
  • 4952 Views
  • 12 replies
Testing USART1 on STM32F429I-DISCO board
Posted on October 28, 2013 at 15:22Hi All, I am working on USART1 device for STM32F429I_DISCO board. [I have already tested my serial device (code) on stm32429i_eval1 board.] I am using following USART setup/pin mapping unsigned int temp; /* Enab...
H UQ by Associate II
  • 2016 Views
ESD problem
Posted on November 05, 2013 at 17:21Recently I had a chance to do some quick ESD tests on my board, unfortunately time was very limited. Some basic information: -STM32F103T8U6 MCU, -USB bus powered, -USB is already protected with USBLC6-2SC6, -Plas...
jzawadzk by Associate II
  • 1243 Views
STM32 Behavior different when on debugger
Posted on November 07, 2013 at 15:44Hello all,Recently I came across a puzzling situation. I have a system that behaves differently depending on whether I am debugging the application or running otherwise. My environment1) STM32F103x running at 8MHz...
kaustubh by Associate II
  • 2468 Views
STM32F4 - Discovery - Example ''Audio_playback_and_record''
Posted on November 08, 2013 at 10:28Good morning,i have a problem with the board STM32F4 - Discovery. I'm using the example ''Audio_playback_and_record'' for this board. I configured this example to read file from a media usb key ( i have uncommente...
fabrizio by Associate
  • 872 Views
STM32F4 Unknown CFSR register constents problem
Posted on November 05, 2013 at 14:31 Hi all, I am porting code from an existing Intel 8031 platform onto a STM32F4 The software performs PID calculations. The softwqare has been running without issues on the 8031 for several years, but...
hermanv by Associate II
  • 2489 Views
