wrong device marking STM32F100RCT6
Posted on March 23, 2014 at 07:57I have chosen STM32F100RCT6 for a new project because of the large number of PWM channels it has. I was not able to activate the clock for timers 12-17, therefore I conduct some more experiments with this chip. Surpr...
Strange MCU behaviour by passing pointer to stucture
Posted on March 24, 2014 at 13:44 Hi All, I'm running some code on Discovery STM32L152 board. I'm getting Hard Fault each time I initiate structure fields in a function: 1. void pid_Init(float p_factor, float i_factor...
Tom by Associate II
  • 2236 Views
stm32f0 interrupt
Posted on March 24, 2014 at 18:59Hi,i want to start an interrupt to leave the sleep mode after a precise that my ADC reads.Could some body help me and put what i shall do in a nut shell?thank you for your attention PS: i am using an stm32f0 discover...
d4ng3r09 by Associate II
  • 1302 Views
External Clock Input for timers
Posted on March 24, 2014 at 21:28Hi,I want to make a timer to count on each rising edge of a square signal on PC.6. I am using STM32F103RBT6. I searched a sample code for that, but I couldn't find anything. What I found are all about timer interrupt...
Adopt STM32F4 Discovery Board Code to STM32F405
Posted on March 22, 2014 at 10:18My application board has STM32F405RG microcontroller.  I tried to use a project came from STM32F4 Discovery Board by just changing the microcontroller from Keil manual ''Project\Select Device for Target 'ST Link Flas...
jim_wei by Associate II
  • 1987 Views
Compile STemWin with a project with STM32F4Discovery
Posted on March 25, 2014 at 11:19 Hi, I'm trying to compile (I have already done the config files) the library with my project, where are present all the include files of the library. I have included the following options for the linker: ...
daniel23 by Associate II
  • 757 Views
what's the real size of STM32F103T6's flash
Posted on March 21, 2014 at 08:28Dear all, According to the datasheet of Stm32f103t6, it is an ARM Cortex-M3 MCU with 32 Kbytes Flash. I am not sure any other STM32 IC have the similar issue.However, today I download a software more than 32k(it is 5...
chenwan67 by Associate II
  • 3095 Views
internal sram read and write
Posted on March 25, 2013 at 08:53hi  i am new to stm32f4. i want to read and write data to the internal sram (4kb). i am using mdk arm for compiling c code.    regards
bilal by Associate II
  • 2763 Views
