spi sending data adress issues
Posted on September 02, 2014 at 19:14 Hi guys , i am trying to figure out how to get stm32f4 discovery board accelerometer work. After checking the lisd302dl datasheet and reference manual (that wasn't too much helpful) ,i went to forum wh...
d4ng3r09 by Associate II
  • 1184 Views
Maximum VCP speed???
Posted on September 02, 2014 at 02:50I am using STM32F2xx and connect it with FT232 chip using UART interfacehttp://www.ftdichip.com/Products/ICs/FT232R.htmand then I connect FT232 chip to my Windows PC, I wrote an application in my PC using .Net to...
ho by Associate II
  • 4575 Views
How to deal with Integer Overflow?
Posted on September 03, 2014 at 04:43For evaluation purposes I got the STM32F0 discovery kit (STM32F030R8T6) with Cortex-M0, and I am using it with the IAR embedded workbench. From the datasheet I know it has no FPU, which is what I need. In my proj...
Qemu for STM32
Posted on August 27, 2014 at 19:33I have installed Qemu on windows. I want to know how to run it and install uClinux on it. I am planning to try some C application for STM32F103 platform. #cross-post #rtfm
shauns87 by Associate II
  • 6575 Views
I2C Start Problem on STM32F205
Posted on August 30, 2014 at 00:53I am attempting to communicate via I2C to another ST device (LPS331AP) and read its sensor values. However, I am not able to initiate the I2C session properly. On the wire, I can see that the start signal is actuall...
nate1 by Associate II
  • 4701 Views
STM32F100R PB5 not enabling internal pull-up?
Posted on September 02, 2014 at 16:54Hello All,I've been bringing up some new hardware around an STM32F100RBT6 processor, and was planning on using PB5 as an input with an internal pull-up enabled. For some reason, none of my boards will enable the ...
Csma ca PLC EVALKITST7580
Posted on September 02, 2014 at 18:01Hello,Currently we are working on a custom board based on the power line modem demonstration kit (EVALKITST7580).I have question specifically regarding the firmware that we have received from ST of this evaluatio...
gnu by Associate II
  • 1112 Views
VCP Problems with HAL Libraries and the STM32F4 Discovery
Posted on September 02, 2014 at 15:22Hi everybody,I have a problem with the VCP. I want to make a UART Connection between the STM-Board (STM32F4 Discovery) and my PC with the MicroUSB. Has anybody a working code for me. I know, I could use a UART In...
mathias by Associate II
  • 1256 Views
Nucleo-F103RB and L3G4200D.
Posted on August 29, 2014 at 12:21 Hello I have a Nucleo-F103RB board and a EVK of L3G4200D. I am try connect this via I2C I have this code for config I2C void Inicializacion_uC(void) { RCC_Configuration_IO(); Inicial...
lemac by Associate III
  • 2413 Views
