Issues with TIMER2 for INPUT CAPTURE
Posted on July 04, 2015 at 19:33 Hello all, i am trying to capture a ppm signal, for the moment i use a steady fixed widith signal of 740hz, with 1050us on period, and 300us off period. The signal going to PA0 and PA1 of my STM32F4 ...
Bogdan by Senior
  • 3964 Views
  • 10 replies
Using Speex library and codes
Posted on July 05, 2015 at 08:25I used STM32F10x_AN2812_FW_V2.0.0 to have speex encoding /decoding on voice. I applied it on my Discovery board. I used encoding functions and then decoding one and saved the data in .wav format using FATFS on micro S...
rizzo by Associate II
  • 689 Views
STM32CubeMX v.4.8 with MDK-ARM v.5.15
Posted on July 02, 2015 at 17:32I am trying to generate initialization code for STM32F427ZITx.Clock and peripherals configuration in a CubeMX is OK.Code generation is OK.All main files (startup, system, HAL drivers, initialization routines) in a gen...
USB HS core in FS mode
Posted on July 03, 2015 at 22:56Hi,I am using a stm32f427 as a USB host/MSC class, with the host library from the STM32F4-Discovery_FW_V1.1.0 package.My question is, if I want to use the HS core in FS mode, how should I set the defines in usb_conf.h...
watchdog handler
Posted on July 03, 2015 at 11:35Hello, I'm trying to develop a watchdog handler to catch, as for exceptions, the last code executed before watchdog. To do that I tried to copy the handler I did for faults and that I found on web.   asm(   ''TST LR, ...
DCMI format support
Posted on July 02, 2015 at 14:10HelloAccording to DCMI section of stm32f407 datasheet and RM0090, RGB565 is supported.Is raw RGB(888) supported too?Thanks.
Can you help me about getting good picture in the STM32
Posted on August 27, 2013 at 11:23I can get this Picture.But I don't know how I can correct this mistake! My code:/* DCMI configuration *******************************************************/   DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMo...
muhammet by Associate II
  • 1719 Views
