STM32F070 ADC single channel issue
Hi,Recently I started working on stm32F07 microcontroller. I am trying to read sensor value using ADC.Issue: ADC value is keep on changing randomly(means its not holding value).Below is my code. Please refer it and help me to figure out the issue.Clo...
VDutt.1 by Associate
  • 2230 Views
SDMMC trace length mismatch
Posted on May 11, 2018 at 01:27 Hi ThereI was looking at AN4661, pg 45 where the signal routing guidelines for SDMMC is given. It has the below bullet points when it comes to skew  The skew being introduced into the clock system by unequal trac...
Resolved! Float value implementation and debugging
Is there a proper way to implement a float value? When i try to declare a float variable and debug via the variables tab and or live expression (global variable) I keep getting incorrect values in some instances. I have included the float library and...
NoviceStm32_0-1734424900179.png NoviceStm32_1-1734424937178.png NoviceStm32_2-1734424981648.png
Issues with KSZ9893 and STM32F427 Integration
Hello everyone,I'm currently working on a project where I'm interfacing the KSZ9893 Ethernet switch with an STM32F427 microcontroller. The setup uses the RMII interface for data communication and I2C for management.Issues i am facing:1.unable to ping...
priyazcs by Associate II
  • 2760 Views
How to use Hyperflash/Hyperbus with STM32H562
Hello,I am trying to use infineons S26KL128SDABHI020 HYPERFLASH memory with a STM32H562VI microcontroller.For now I am just trying to do a simple write and read manually to make sure that everything is working.I use the OCTOSPI module with Hyperbus-m...
J_Kirsch by Associate II
  • 4196 Views
