STM32F103 Does not RESET on Power Reset
Posted on March 26, 2016 at 09:46Dear All, I am facing a very strange problem in STM32F103RET6. It is showing completely random behavior on Power Reset. On some PCBs it RESET on every power Reset, while both PCBs have same hardware(means identical h...
STM32F3 12bit DAC with DMA - issue
Posted on March 28, 2016 at 09:59 Hello everyone, this is my first post on the forums. I've been following the posts for awhile and now I have myself faced a problem I can't seem to fix. I'm using a NUCLEO-F334R8 evaluation board and HAL ...
lkaino by Associate II
  • 1964 Views
stm32f769 maximum dsi resolution
Posted on March 25, 2016 at 14:39Hello! I want to connect tft display with 1280*720 resolution via DSI interface. TFT panel has 4 differential inputs for data. There is no reference manual for stm32f769 controller on this page http://www.st.com/web/...
STM32L Possibility of timer expiry missing
Posted on March 25, 2016 at 11:51I have Timer1(TIM1) channels configured @ different frequencies.I have loaded appropriate values inside the uhCCRX_Val register as well.The frequencies for channel 1,2 and 4 are 10,100 and 1 Hz , that means i must ge...
darla14 by Senior
  • 3377 Views
  • 11 replies
My first STM32 based circuit, is this circuit ok?
Posted on March 18, 2016 at 14:48Hi,This is my first time working away from Arduino.I am creating a simple CAN bus analyser using a STM32F105RBT6I have used parts of circuits from various evaluation boards. But I am mainly concerned about the Power ...
terry23 by Associate
  • 1046 Views
STM32 Virtual Com Port problem [solved]
Posted on October 30, 2015 at 13:30 STM32CubeMX generate that code for my STM32F4Discovery (STM32F407VG): /** * @brief CDC_Receive_FS * Data received over USB OUT endpoint are sent over CDC interface * through this function. * * @no...
chief by Associate II
  • 3110 Views
null
Posted on March 25, 2016 at 18:15
techkit by Associate
  • 1267 Views
Clock configuration for stmf411 series mcu
Posted on March 28, 2016 at 15:21Hi STM, As part of our project we are using STM32F411RET6 series MCU, We have followed clock configuration from the below link http://www.st.com/web/en/catalog/tools/PF257927 As Maximum clock for the MCU what we are ...
