STM32F4 DMA interrupt not generated all the time
Posted on January 27, 2017 at 11:16Hello All,I am using STM32F407 discovery board. I am using SD IO card with this board.I tried configuring DMA for data transfer.I observed that the interrupt (DMA interrupts) are not generated after Transfer comple...
STM32F429i-DISCO with 512Mbx16b memory
Posted on February 06, 2017 at 12:34Hello, in my project i need to have more SDRAM than original 4M*16b.So i ordered 32M x 16b ISSI IS42S16320d-7TL that fit's inside the same footprint, and i soldered single jumper cable to PG2 as well as modified G...
Using TLC2543 ADC chip on STM32L476RG
Posted on February 08, 2017 at 11:33Hi allI followed the post below to setup tlc2543.http://blog.csdn.net/haozi_1989/article/details/6111776 datasheet http://www.ti.com/lit/ds/symlink/tlc2543-ep.pdf Because the STM32L4 series used HAL library not SP...
Resolved! STM32L011K4+LSM9ds1tr SPI wrong readings
Posted on January 26, 2017 at 13:31Hello, we are having problems with communicating to sensor LSM9ds1tr via SPI with sm32l011k4 mcu. The problem is that SPI seems to work good and looking with logic analyzer proves that everything is okey, we are se...
STM32CubeMX with Eclipse for Nucleo STM32F303RE
Posted on February 07, 2017 at 19:33I have a Nucleo STM32F303RE that I'm using with the Eclipse IDE.  I've downloaded and installed the STM32CubeMX plug-in, but I have idea how to activate it to take advantage of it....Are there any step-by-step exa...
Standard C++ library
Posted on February 08, 2017 at 15:51I'm using C language onto my STM32 chip and would like to go to C++.When I develop for x86 architecture under C++ I always use libraries like Boost or POCO to simplify and secure my code.Is there some libraries ta...
