USB CDC + FreeRtos Queue Problem
Posted on June 21, 2017 at 07:06Hi,I'm using Nucleo F207ZG , I'm trying to send the message using xQueueSend from CDC_Receive function but the following i cant because of priority level ,Program received signal SIGINT, Interrupt.0x080030dc in vPortV...
How can I calculate the CRC in java ?
Posted on July 04, 2013 at 04:30 Hello All, I have a stm32f4 discovery. I'm sending out messages the first part is my ''header'' the rest is ''data'' then the tail is the crc value from the hw perph. This is the code I use to send the messag...
read gps data on stm32f103
Posted on June 20, 2017 at 16:41Hello dear ST programmer!At least one month I`m trying to implement gps neo-6m module with my inemo-discovery board and I really get nothing, i have already implemented altimeter and it is works good now I need to rea...
How to receive a message via CAN with STM32F105
Posted on June 21, 2017 at 16:00Hi,This is my first time programming a microcontroller, so a lot of things are still new to me and I'd like to have some infos about how to correctly receive a message via CAN.I've read the HAL Driver documentation of...
Issue with USB Host Mass Storage device
Posted on June 21, 2017 at 15:51HiWe have STM32F429 based board.I am trying to read USB mass storage device on this board.I have referred sample code provided in STM32Cube_FW_F4_V1.12.0\Projects\STM324x9I_EVAL\Applications\USB_Host\MSC_RTOSWhen devi...
SRC236 example no found
Posted on June 21, 2017 at 10:46SRC236 library documentation shows that ST provides an integration example on STM32F411VE discovery ,But I don't find any example about SRC236 ,So is there someone who knows where SRC236 integration example locate?tha...
Howard Lu by Associate II
  • 1300 Views
STM32F411 I2Cs
Posted on June 21, 2017 at 13:00Hi,I am using two I2C busses with STM32F411 uController (I2C1 and I2C2) and I need to implement a pass-through between those two: messages coming from I2C1 shall be forwarded to I2C2 and viceversa.Is there any example...
Luca R by Associate II
  • 1299 Views
