2017-06-21 6:51 AM
Hi
We have STM32F429 based board.
I am trying to read USB mass storage device on this board.
I have referred sample code provided in STM32Cube_FW_F4_V1.12.0\Projects\STM324x9I_EVAL\Applications\USB_Host\MSC_RTOS
When device is connected, I am getting event HOST_USER_CLASS_ACTIVE from library.
When I receive this event, I am sending device connected message to usb host application task.
When application task receives device connected message, I am calling f_open API.
When f_open is called, I get hard fault error.
When I debugged issue, I observed that when USBH_MSC_RdWrProcess() is called, USBH_LL_NotifyURBChange() is called through ISR twice. First time it successfully calls osMessagePut ( phost->os_event, USBH_URB_EVENT, 0);
But next time it fails as
phost->os_event has garbage value and hard fault is generated.
Has someone faced similar issue? Any pointers will be great help.
Thanks in advance.
