EVALKITST7580-1 GUI problem
Posted on October 18, 2017 at 11:17Hi all,I'm using X-Nucleo-PLM01A1 with NUCLEO-F401RE and NUCLEO-L053R8 boards. I followed the guide at this link to install the EVALKITST7580-GUI and the proper firmware.https://my.st.com/content/my_st_com/en/produ...
LED don't light on Nucleo STM32F411RE
Posted on October 14, 2017 at 12:59Hi, I'm getting started with the Nucleo STM32F411RE, and the LED don't light !Here is my main.c ://*****************************************************************************////! \file main.c//! \brief main appl...
Stm32Cube MX Delete Old Firmware Files
Posted on October 17, 2017 at 14:20Hey guys,is there any way to remove old Firmware packets, which have been imported via a local stm32mcube source in cubemx.If not how can I be sure that when I start a new Project cube mx uses the latest libraries?...
edelmann by Associate II
  • 3755 Views
Resolved! STM32F767ZI Timer Interrupt
Posted on October 11, 2017 at 23:35Hello,I am having some difficulties wrapping my head around what's happening with my TIM3 interrupt.  I am creating a timer class for my application.  It needs a 1 microsecond resolution.  For some reason I can onl...
RTC not interrupting every seconds
Posted on October 16, 2017 at 15:52 Hi I was running RTC with stm32f I use cmsis and using LSE(768 khz) for rtc. I want to trig the RTC_IRQ on each second. How can I active it ? Its my code for adjusting rtc static void RTC_Config(void) {  RT...
Problem in getting I2C working with 100KHz clock rate
Posted on October 03, 2017 at 00:53Hi, I don't know if anyone has ever encountered the same issue I am encountering. When I set I2C clock rate to 100KHz and use HAL_I2C_Master_Receive command to receive I2C data, the I2C_WaitOnRXNEFlagUntilTimeout f...
Josh Liu by Associate
  • 1654 Views
