Driving ADXL345 via SPI
Board: STM32F407G-DISC1IDE : StmCubeIDEHello,      I am trying to drive ADXL345 accelerometer sensor via SPI. I succeed in receiving the device address (0xE5).However, afterwards, when I tried to read two registers' value consecutively. I always read...
SAI configuration for 2 PDM Microphone in Stereo Mode
Dear ST Community Member, I hope you are all doing well. We are currently acquiring audio using the STM32G4 and 2 PDM microphones in stereo mode. I would like to know how to split the left and right channel data. Could you please provide me with the ...
IOT_Dev by Associate II
  • 1461 Views
CTS signal on USB CDC
Posted on May 15, 2018 at 09:13Hi,I need to send the CTS status from my target hardware to the Virtual com port driver in windows, USBser.sys.I have managed to do all the other handshake signals (DTR, RTS, DCD and DSR) working except CTS. Apparently...
Block for sending values through the UART
Hello, I am trying to wire STM32F103C8T6 with DS18B20 sensor and I realize that after some actions it stopped to work and no data through the UART sent:     Probably it's not big deal, but I have no idea why UART completelly blocked and sending no in...
stm32-proteus.png cube-ide-clock-configuration.png stm-32-rcc.png usart-1.png
Resolved! STM32U5A5VJT6Q VDD11 connection
Hi,STM32U5A5VJT6Q has 2 VDD11 pins. Should these be connected together using an external trace on a PCB? I did look at Nucleo U5A5ZJ-Q schematic but I'm still not sure.Thanks,Adam
awocrf by Associate III
  • 1204 Views
USB Microphone
I'm trying to send a Audio data from MEMS microphone to Device through USB. I had defined a configured a descriptors accordingly. But I'm facing Error message that is *!*ERROR: No open pipes!.[Port1] : USB Composite DeviceIs Port User Connectable: ye...
pugazh19 by Associate
  • 1716 Views
Resolved! STM32F103 SPI Master receive only mode
MCU : STM32F103VET6 (Master & Slave) STM32 Cube MX : 6.12.0 Firmware package version : 1.8.6 Master MCU configure- Receive only Master- NSS : Disable ( However, different GPIO sent a signal for the slave NSS )- Clock 72 Mhz - SPI Prescaler:  4 (9.0 M...
Ryuyeon by Associate
  • 1178 Views
