STM32411RE printf
Posted on October 01, 2016 at 20:58How can I print data acquired from a gyroscope on RealTerm using printf. I'm using a STM32F411RE and I used CubeMX to set registers.  Thanks! #printf
marco3 by Associate II
  • 2580 Views
stm32l4 iot BSP
Posted on June 03, 2017 at 03:54When will the MXCube library add support in STM32L4 for the iot board?  It is not in the latest 1.8.0?
STM32CubeMX for EWARM - Workspace name
Posted on June 20, 2017 at 15:00STM32Cube always generates EWARM Workspace file 'Project.eww'. No matter if settings  like 'L476_1' are used for project name. How to control workspcae name out of STMCube32MX?Best regards
JuM by Senior
  • 2379 Views
STM32CubeMX Creat debug and release projects
Posted on June 20, 2017 at 12:58Using STM32CubeMX (use V4.21.0) one can 'Generate Code' for e.g. the IAR EWARM toolchain.If creating a new project in EWARM standalone, then EWARM creates two Projects Debug and Release.Any way to tell STM32CubeMX to ...
JuM by Senior
  • 1212 Views
STM32F103 Tim1 PWM
Posted on January 22, 2018 at 07:48hi,I am using SMT32F103VE, try to use TM1_CH1 ouput PWM at GPIOA_8, it can output correctly in debug mode with J-link, but can't output in normal mode(Power up after flash).The below is code. TIM_TimeBaseInitTypeDe...
kent gu by Associate III
  • 5351 Views
  • 10 replies
FatFs F4 SDIO broken on latest CubeMX
Posted on May 30, 2017 at 01:36The latest version of CubeMX (4.21) with F4 Libs (v1.16) using the SDIO controller seems to have broken FatFS support.  ff.c needs a file that declares the character sets being used because it contains a couple of util...
