USB HID Device
Hi MembersCan some one, please explain what exactly is stm32 USB HID Device.(specifically mouse)..Does it mean that we read a mouse (buttons and cursor) attached to PC with stm32?
asim khan by Associate III
  • 1437 Views
PWR register and wakeup from Standby mode
Hello, I want to know whether PWR_CSR resets or not when exiting the standby mode using wakeup pins. there is an ambiguity in the RMin STM32F446RE MCU RM document @ 6.1.2 Power reset it is mentioned as below "A power reset is generated when one of t...
RN by Senior
  • 872 Views
Using STM32CubeMX to interface KSZ8863 with MII (STM32F207ZG)
Posted on December 15, 2017 at 17:21Hello All,I'm interfacing a KSZ8863 (Micrel, 3 Port Switch with 2 PHY and 3 MAC) over MII from a STM32F207ZG. I've used the STM32CubeMX to generate the code with the LwIP Stack and FreeRTOS.So far, I've successful...
ame by Associate II
  • 3862 Views
Documentation issue STM32 discovery kit IoT node
Hi,In this document, https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/d0/f7/45/d7/3b/96/47/b3/DM00285842/files/DM00285842.pdf/jcr:content/translations/en.DM00285842.pdf Where to find this firmware package (see the photo),...
Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\ST\FlashSTM32F401xE.flash
Hi.Here I am on a task of Migrating a code which is working the STM32F411RE processor to STM32L476RG. I have done the all the steps as per the guidelines given by the ST. I am facing an error, " Failed to load flash loader: C:\Program Files\IAR Syste...
Website issue
Hi there is an issue in the website and there is no way to contact the webmaster. The issue is in the contact list here: https://www.st.com/content/st_com/en/contact-us.html# , I've tried to send the email to: 1)AME_BO_West_Inquiries@list.st.com 2)me...
STM32F417 DAC offset
I'm using STM32F417 MCU for our system design, DAC1 and DAC2 is employed to output variable DC voltage, but both channel has about 50mV offset ( Set_DAC_Out1(0); ). In the user datasheet, there is no register related to adjust offset. Is there anyo...
