QuadSPI hangs with BUSY after 4 GB indirect read
I'm using QuadSPI in indirect dual-flash read mode to transfer data from an external chip (not flash memory). According to reference manual, when FSIZE = 0x1F and DLR = 0xFFFFFFFF, the transfer should continue indefinitely.However, with STM32H743ZIT6...
jpa by Associate II
  • 784 Views
ETR prescaler bandwidth on STM32F401RC
Hello,I tried to prescale the TIM2_ETR signal on STM32F401RC, to increase the bandwith. In theory the ETR signal max frequency is 1/4 Fclock = 21 MHz, but it can be increased thanks to the prescaler. The RM0368 manual (STM32F401 reference manual) wri...
TGUEN.1 by Associate II
  • 2044 Views
How to make the STM32373C-EVAL SDADC to work?
Hello,I am working on the stm32373C-EVAL but I can't get the SDADC to give me satisfying values.I am following the UM1786 "how tu use this driver" instructions on p°594:I fill in the HAL_SDADC_MspInit(), the HAL_ADC_Init() is used, I call HAL_SDADC_P...
RKula.1 by Associate
  • 742 Views
Connect a pin to two inputs
Is there a way to connect some pins to both ADC and comparator inputs, for example ADC_IN2 and COMP1_INP? It should be possible because they both are inputs.
Shipping addredd.
I want to buy eval bds in my basket.But l cannot complete the order because the order forms address CITY section does not list my city GOYANG.Local sales needs one month delay they do not have in stock. I am buying one Nucleo144stm32f767 and one Nfc0...
