Resolved! Strange ST factory calibration on STM32f042k6 (ADC)
Hello,I'm trying to use temperature sensor and the internal voltage reference (VREFINT) of the STM32f042k6.Here is the extract form the datasheet (page 19/117) :When I measure these values, I don't have the same values than ST.For example, let's watc...
ValentinG by Associate II
  • 2062 Views
Better learning resources for Bluenrg-2?
Hey, folks.How are you people learning how to use the capabilities of your MCUs? In particular, I am trying to program a Bluenrg-2 board for a temperature control application. I would like to get better information on using the Multi-Function Timer...
BBeau by Associate
  • 909 Views
AES-CBC(128 bit) Encryption for STM32H750VB IC
I am using STM32h750VB for a Project. I need to use AES -CBC Mode of Encryption.I have downloaded the cube-cryptolib and when I searched for the crypto code of my IC, I found that the AES CBC code is available for STM32H743ZI-Nucleo..Can i use the sa...
What's the bXCAN RXD recessive signal on STM32L476?
I'm reading RM0351 for STM32L476, "To be synchronized the hardware has to monitor a sequence of 11 consecutive recessive bits on the CAN RX signal." Is RX recessive bit a digital high or low signal? I couldn't find the info on the datasheet which onl...
ANguy.1 by Associate II
  • 1225 Views
My data are being send in loop despite the datas are ACK.
static void FDCAN_Config(void) { FDCAN_FilterTypeDef sFilterConfig;   hfdcan.Instance = FDCAN2; hfdcan.Init.FrameFormat = FDCAN_FRAME_CLASSIC; hfdcan.Init.Mode = FDCAN_MODE_NORMAL; hfdcan.Init.AutoRetransmission = ENABLE; hfdcan.Init.TransmitPa...
SBACO by Associate III
  • 3704 Views
