DMA FIFO error on DAC when writing second time
I am trying to use DAC Channel 1 on STM32H7 with DMA to control the ramp-up of a PA. The DAC must always be driven (enabled). A ramp-up sequence is written at the start of a burst and a ramp-down at the end of the burst.The FIFO error flag is set on ...
PWint by Associate III
  • 833 Views
DAC output in STM32L151RCT6 MCU is not constant.
Hi,I am using STM32L151RCT6 MCU and creating the project in STM32cube IDE .i implemented DAC peripheral and kept 1.52 As input and did calculation like:float value = 1.52; // Dac outputuint32_t var; var = (value * 4096)/3.3 ; // From datasheet  HA...
MBhir.11 by Associate III
  • 1734 Views
documentation errors in RM0444
Offset values shown in Table 84 are out of range according to Table 1.Also, "Address offset" of each COMP registers is different from the table.Section 10.1 says that the assignment of DMAMUX request multiplexer outputs to DMA controller channels is ...
0690X000008i5niQAA.png 0690X000008i5o2QAA.png 0690X000008i5o7QAA.png 0690X000008i5nxQAA.png
arufa by Associate
  • 1459 Views
I want to use CubeMX examples with CubeIde
I just started using CubeIde but using Cube examples gives a lot errors. Should I just copy all the .H and .C files (from where?) somewhere or is there a better way.I have 32H750 and 32F746 Discovery boards and my own boards.
LMI2 by Lead
  • 975 Views
