2021-03-22 9:08 AM
2021-03-22 11:18 AM
Probably as close as you can get from ST, if you need more than 64KB FLASH you could always have someone remove the R8 and place the RC (check if the die is the same first)
https://www.st.com/en/evaluation-tools/nucleo-f302r8.html
