Programming an STM32F769NI to count sheets of paper
Hello! I've recently bought that kit and I would like to use the "Paper Cutter" interface developed by Embedded Wizard to display the number of remaining sheets. Honestly, as I am a newcomer in that field, I don't really know how I could do that, par...
LleytoN by Associate II
  • 932 Views
the phase of PWM output signal with HSE clock edge
Hi In my system using STM32F407, there is a period PWM signal output triggered by external comand. However we find that the phase between PWM singal edge and HSE edge is changed cycle by cycle, is F407 capable to config the phase stable?when received...
jhl14 by Associate II
  • 850 Views
Problems with USART transmission using DMA
The problem is as follows, when transferring data via USART, without using DMA, the data is sent (in an attachment). When I start using DMA transfer, no data is sent (in an attachment). Maybe I am doing wrong DMA settings in the USART configurator? I...
VVlas.1 by Associate II
  • 4565 Views
When will Reference manuals really be usable?
I write code and manuals for 36 years and I've learned that those are too often written by a person who fails to put himself in the readers position. A reader who's not familiar with the topic otherwise the material was not required in the first plac...
EGi by Associate III
  • 1745 Views
  • 4 kudos
BxCAN Frame and Form Errors Help
Hi Stm Forums. I'm a college student working on my capstone project that requires CAN bus communication between two STM32F1 and one STM32F4. For a little background each of the STM32F1's job is to read in sensor information, filter, and send that dat...
AMont.4 by Associate
  • 1602 Views
Resolved! STM32G474 FDCAN3 bit timing
Hello All,I am trying to send some classic CAN messages via the FDCAN3 module on STM32G474CE device. I have only pins for FDCAN3 free. My FDCAN clock is PCLK1 with a frequency of 64MHz.When I try to transmit a CAN message, firstly there is no transmi...
ma.alam9 by Associate III
  • 1806 Views
