STM32F4 SAI data latch
Hello​​Our new product use a STM32F427 and a ADC(AD7768-4) the data input connection is the SAI(serial audio interface). The STM32F4 SAI mode is the slave mode.​​The ADC sends SAI_SD signal and SAI_FS at rising edge.Therefore, we think that the STM3...
TFuji.5 by Associate II
  • 1464 Views
Resolved! Why is Sigma Delta ADC 32767 at 0 volt?
Hi!I'm trying to read Sigma Delta ADC for 16-bit. It works, but it seems that everything is reverse.For single Sigma Delta ADC I get 32767 (0x7FFF) when I apply 0 volt.For differential Sigma Delta ADC I get 65553 (0xFFFF) when the difference is 0 vol...
DMårt by Lead
  • 1250 Views
Resolved! STM32G0 Variable square wave generation
Hi all, I'm using a NUCLEO-G071RB board and I simply want to generate a variable frequency square wave. I started from project TIM_OCToggle found on the examples.My problem is that TIM1 channel 1 has a fixed frequency and even if I change it through ...
ECast.12 by Associate II
  • 9446 Views
  • 12 replies
My device is setting watchdog during powerup.
Dear ST community,We are using STM32L152VBT6-LQFP100 Pin IC in our device. we are using it for a long time. recently we observed that our 2 boards are setting watchdog during Powering the Board.the boards are going in the loop of watchdog reset. what...
VinayakP by Associate II
  • 5277 Views
  • 11 replies
Resolved! STM32 SDIO 1 bit + DMA double writes (also 4 bit isn't working)
Hi all!I'm trying to configure SDIO in several modes:1 bit1 bit + DMA4 bit4 bit + DMAOnly 1 bit is working for now. When I enable DMA in 1 bit it double writes things into my files. 4 bit mode on the other hand mostly gives me error " FR_DISK_ERR" af...
0693W00000D1bVKQAZ.png 0693W00000D1bW3QAJ.png 0693W00000D1bVKQAZ.png 0693W00000D1bXGQAZ.png
bmak by Senior
  • 3371 Views
Resolved! Modify the link file to locate the stack/heap into DTCM area
Hello,Someone have a document that give explications/informations on how modify the link file ?I must optimize ma code performance and I would realocate the stack/heap, the time critical functions, into the TCM area.I know the way to locate variable...
ABITT.1 by Associate III
  • 2394 Views
