Do you know of https://community.st.com/s/group/0F90X0000007uqASAQ/feedback-on-the-stcom-website ? No? I though so. It can't be found in the list of "Groups" in the menu here; and it appears that ST removed "website feedback" from st.com pages (or I ...
In STM32F103C8T6 , I am using timer1 channel 1 and channel2 for PWM generation using DMA.TIM1_CH1 uses DMA1_Channel 2and TIM1_CH2 uses DMA1_Channel 3.NOW i am usingfull transfer interrupt : HAL_TIM_PWM_PulseFinishedCallbackand half transfer interr...
I am using my boards with STM32F303VBT6, There is a UART 3 hang after run for 1-2 hours. There is no UART interrupt of the receiver. I monitored the RS232 signal is there. After reset the receiver board, the receiving date can be recovered.What is th...
Hello, i get the wrong data from my UART connections. I try to transmit the data "HELLO WORLD\r\n" from my STM32 to my PC with a UART-USB adapter. Every cycle my LED blinks the transmitted signs are "…ýQa[gwëåÿÿÿÿÿÿÿÿ{FF}«" I tried STM32F103RBT6 and...
Hi all,I'm implementing a DAQ (data acquisition chain), using STM32H747Xi Discovery board.What I need to do is sample as fast as possible 1 adc channel and do some light processing on the data. I need to understand how to configure the system to get ...
Greetings !We are designing our custom carrier board using STM32F769 Controller . Here we are using 2 separate SDRAM chips each of 16 MB size with same manufacturer (AS4C16M16SB-7TCN) . We have used FMC configurations pins as : FMC_SDNE1 & FMC_SD...
I'm using an STM32G070CB for a project and need to store 6 bytes worth of data to the flash memory. The MikroPascal PRO for ARM compiler that I'm using has a flash library for this (I assume it's their version of the HAL procedures that I've seen els...
