Resolved! STM32F4 works properly only when I press the reset button.
As a newbie user, I tried to do basic code in STM32CubeIde which includes only potentiometer and leds. My goal is that when Potentiometre's value rise, different led will light. The code works but when I rise the potentiometre's value the leds don't ...
BDuma.1 by Associate II
  • 2971 Views
Resolved! STM32H7xx HAL SD card power management extension support
Is there support in the HAL for the power management function on SD cards as per section 5.8.1 of the SD card specification (Physical Layer Simplified Specification Version V9.00)? I am talking specifically about the Power Off Notification feature.My...
AHaup.1 by Associate
  • 1661 Views
Alternative Dev boards to NucleoF401?
I have some projects I am working on that I'm starting with Nucleo and VL53L5 satel.The board is too large, so I saw the Blackpill which has F411.Can anyone tell me please if the F411 will run the same code?
TChap.3 by Associate II
  • 4591 Views
Does STM32 use C or C++?
What are the main differences between using C and C++ for STM32 microcontroller programming? Which language is better suited for different use cases, and what are some factors to consider when choosing between the two for embedded system development?
wlee.1 by Associate
  • 13719 Views
Nucleo-F303RE Getting ADC Data Speed Problem
Hello everyone,I'm trying to get ADC(DMA) data on the NucleoF303RE STM32 board. The sampling speed is 1Msamples/s. When I apply a sinus wave I see data losses on ADC data. I tried to read data with a serial port and save it to an sd card. Both of the...
ADynr.1 by Associate II
  • 9617 Views
  • 20 replies
