STM32 MCUs Motor control
GMA by ST Employee
  • 1838 Views
MCSDK 6.4.0 is out!
GMA by ST Employee
  • 4992 Views
Zied b. by ST Employee
  • 9746 Views
Resolved! MC_DURATION Fault in B-G431B-ESC1 software
I am getting the fault of MC_DURATION after running for few seconds in my customized board but software is same as B-G431B-ESC1. I am not sure why this error is happening, any advise? I have changed the REGULATION_EXECUTION_RATE to 2 from 1 assuming ...
SRedd.5 by Senior III
  • 1696 Views
BLDC switching sequence from PWM to GND
Hi all,I am working on BLDC motor control using Hall sensors. At the moment, the motor seems to be running fine, however, I have noticed something strange in one of the sequences (this can be seen in the attached image taken from an oscilloscope). Wh...
adromo95 by Associate II
  • 1127 Views
Resolved! Active low LIN Mosfet driver and software changes.
I am using the software of b-g431b-esc1 and the driver used in the board as per schematics is in my board the micro is RB series but the problem is with the Mosfet driver which has an active low signal, IR2108What changes do i need to make in the sof...
_legacyfs_online_stmicro_images_0693W00000biyXCQAY.png _legacyfs_online_stmicro_images_0693W00000biyXlQAI.png
  • 2345 Views
Resolved! Motor Profiler stuck on "Checking ST-Link connection"
I'm trying to use the Motor Profiler software through my Motor Controller SDSK 6.1.1. When I launch the profiler, I Select my boards - Nucleo-F302R8 and X-Nucleo-IHM07M1 3Sh. Then I set the motor parameters to match my motor Bull Running BR2804. When...
_legacyfs_online_stmicro_images_0693W00000bj8tCQAQ.png _legacyfs_online_stmicro_images_0693W00000bj8tHQAQ.png _legacyfs_online_stmicro_images_0693W00000bj8tMQAQ.png _legacyfs_online_stmicro_images_0693W00000bj8t8QAA.png
ABart.5 by Associate II
  • 3167 Views
6 Step Sensored MC SDK 6 Issues
Devkit: (B-G431B-ESC1)Motor: (Pole pair = 3, (6 total magnets))Hall Sensor: Honeywell SS41F, 40 mechanical degree placement and 120 electrical (odd mechanical placement due to 3 pole pair)Software: MC SDK V6.I am trying to use 6-step sensored control...
Resolved! How to drive the high-side of the bridge in STSPIN32F0?
Hi all,I am new to motor control, and I am currently working with the BLDC motor driver board STEVAL-SPIN3201 (based on the STSPIN32F0). I am trying to generate the corresponding PWM signals to drive a BLDC motor. Although the low side of the bridge ...
  • 1356 Views
Resolved! How do you set up sensored six-step control? (in a kit, that supports it, but doesn't have an example file for it)
I'm building a project around the B-G431B-ESC1 board, that claims to support hall sensored 6-step control, but in motor bench there are no example files for this (only sensorless electric speed control files). I know you are supposed to generate file...
