2025-01-06 3:39 AM - last edited on 2025-01-07 3:37 PM by Andrew Neil
I am trying to implement basic DHCP Protocol using STM32F439ZIT6. But I am unable to get the IP being assigned by the DHCP Server. There are no errors in the code, but I am not getting the IP. Don't know why it is giving DHCP Timeout. I am attaching my code, please go through the code and let me know the solution. Am Struck here for a while!
Thank you
2025-02-04 10:17 PM
@STea Tried using cloning and I think it is because of the version mismatch, the error previously. No error and code compiled but I am getting the below in the ITM.
Kindly help me resolve this issue!
Thank You
2025-02-11 2:09 AM
Hello @vbk22398 ,
you can disable ITM as you don't need it in your case and try the example out this can be done by commenting LWIP_DEBUG in lwipopts.h.
