I would like to use the TCP/IP protocol (with LwIP, HAL library, without freeRTOS) in a project but I face some portability issues.
Hello,I would like to use the TCP/IP protocol (with LwIP, HAL library, without freeRTOS) in a project but I face some portability issues.I'm starting with TCP echo client example as in chapter 6.1.1 of UM1713 document.I used the 1.26.2 version of STM...
DLUCA.1 by Associate II
  • 4226 Views
Write my own library
Hi there !I want start to write my own library, and step by step stop to use HAL library. Please some one know where i can find information, tutorial , or know some good book and whenre i can buy ? or webbinar ? Thank you Sergio
SGian.1 by Senior
  • 4195 Views
What did i miss? How to change application boot address correctly? I want to use my application with bootloader. MinGW + VS Code + openocd + make. STM32L452CC
Most time i use IAR to create an application. But want to use mingw and vs code instead iar. I`m already have a bootloader which is working fine with my IAR applications. Here is the sequence for IAR:I generate project for IAR via CubeIDEIn IAR i go...
SBond.3 by Associate
  • 1141 Views
Why HAL_I2C_IsDeviceReady return HAL_ERROR
Hello folks,Since my last post, I still couldn't solve my I2C communication problem. I thought maybe return is not HAL_OK for my function so that I couldn't find any I2C addresses. And my guess was correct. I'm getting HAL_ERROR but it doesn't mean a...
SKAŞ.1 by Associate II
  • 11915 Views
  • 12 replies
