STM32H750 and Sd Micro card use SDMMC FATS?
Dear ST Microelectronics Team! I am coding commnuication between STM32H750 and SdMicro use SDMMC - FATS from cubemx. But I have a proplem about commnunication about STM32H750 and Sd Micro using SDMMC FATS.Step 1: I open a file by using funtion: 1. re...
snguy.1 by Associate
  • 1427 Views
Resolved! STM32 H723ZG ethernet UDP server example
hi its been months since i started my journey with the ethernet port i need to communicate via UDP to a pc to get data from the board and send i succeeded some times where some of my projects worked for a while then stopped sometimes the board doesnt...
bakhti by Associate II
  • 6105 Views
X-CUBE-STL - Safe Limited Speed
Hi,I would like to use the X-CUBE-STL on a STM32F446RE to trigger a STO (safe torque off) and a SLS (safe limited speed) with PLc. The STO is no problem at all, since the controller can trigger that directly by using two input GPIOs and one output GP...
HL?�t by Associate II
  • 1147 Views
Resolved! [Solved] STM32F446 SDIO FindSCR Fifo is zero
I have a strange issue. I used the SDIO Interface on a F2 and a F429 without issues. But on the first usage with the F446 i run into a strange problem.With the Logic Analyzer i am observing the communication.Card Init:Requesting Card Type, CSD and CI...
