USB_host MSC with stm32f746
Hi, after of much struggle in the programming, seeing the tutorial of controllers_tech, can create files and directories in usb memory. I had problems with these case, when insert the usb memory the flow of program enter in Application_Start but neve...
RMasi.19 by Associate II
  • 2120 Views
Resolved! Init RTC failed - timeout error - stm32wb10cc
hi,I configure my micro to work on internal clock by cubemx - this is the clock configure://#############################################################################################################//                 Init Device:  System Clock Con...
aviel by Associate II
  • 3876 Views
STM32 G0 FDCan In Classic Mode
I have a Nucleo G0B1RE board and I am trying to get the FDCan peripheral up and going.  There is no sample application specific to this board so I have copied the initialization from the C1 eval board files.  I am just trying to send classic frames (...
ttatakis by Associate III
  • 1437 Views
1 bit SPI data sending - STM32F7
Hi all !  I want to transmit 1 bit on the SPI1 of my STM32F7.I see that the minimum datasize to transmit is SPI_DATASIZE_4BIT. So I guess I can't send only 1 bit of data on my bus.  I am wrong ? My final goal is just to have 1 clock period on the SPI...
Remi99 by Associate II
  • 3195 Views
STM32WB55 Custom profile
Hello, Could you please guide me in creating a custom template for STM32WB55 BLE? I am trying but I don't know why the Bluetooth is not starting or what. I am not able to detect device on the STBLE app.
Omkar by Associate
  • 1680 Views
No ACK received form SPI Bootloader
NB: To view the kvdat files I have attached as part of this post use the KingstVIS Logic Analyser software. Freely availible from https://www.qdkingst.com/en/download . You will also need to decompress them using XZ and TarHi All,I'm trying to get a ...
Resolved! I2C slave mode, slave not respond to master
Hello everyone! I have been complaining about this for 1 week. I can't make "HAL_I2C_Slave_Seq_Transmit_IT" send data to the master, but Slave to master ACK works fine, does anyone have any advice to give me that can guide me a little? I am using the...
modonga by Associate II
  • 6149 Views
