Resolved! B-L462E-CELL1 eSIM activation failed
Hello,After having purchased a  B-L462E-CELL1 eval kit with pre-provisioned Truphone eSIM and having followed the UM2743 eSIM activation steps, I still don't see the eSIM marked as activated on the Truphone IoT Dashboard after one day.Truphone suppor...
EAlai.1 by Associate
  • 2729 Views
STM32G0B1 OpenBootloader using I2C Protocol
Hi ST Team,I'm using ST's openbootloader using i2c protocol. But facing following issues while implementing using stm32cubeprogrammer and ST-Link V3set:1. After reset the user application is not running2. Not able to flash new firmware after 1st time...
Pranil by Associate
  • 1538 Views
Resolved! STM32F103C8 using SPI2
Hello,i am trying to interface 1.8 inch SPI TFT Display 128 x 160 to the STM32F103C8 using SPI2.https://www.az-delivery.de/products/1-8-zoll-spi-tft-displaySPI1 is used for LoRa, i thought to connect TFT too to SPI1 using addresses but i am affraid t...
hamo by Senior
  • 26659 Views
  • 65 replies
  • 4 kudos
Resolved! 1 MCU(stm32f103) - 2 Master SPI Communication error
  Hello, I am trying to control two Motor Drivers (TMC5041) through SPI communication using STM32F103. The compiler uses IAR. I am trying to communicate with two SPI Masters, but perhaps due to an initial configuration issue, only one SPI is control...
Jdogk by Associate III
  • 4011 Views
Resolved! My own L452 board stops working when I press NRESET, problem with debbuging but not flshing.
Hello to everyone,I have crereated my own STM32L452 board with battery power supply.It dosent run as expected. Sometimes I need to discharge caps and sometimes this is not helping. When it works and I connect nreset to groung and release it stops wor...
HHako.1 by Associate III
  • 3233 Views
