Resolved! Problem with HAL_TIM_RegisterCallback
Hi,can someone help me ? I do not know how to use "HAL_TIM_RegisterCallback" function.My unsuccessful trial is in attachments. Can someone correct it ?  + to attach the corrected version ?I tried this example:  https://deepbluembedded.com/stm32-timer...
JerryMC22 by Associate III
  • 1439 Views
STM32L496RGT SDMMC DMA FATFS
Hi, in CubeMX 6.1.1 with FW package 1.16.0. If I choice in SDMMC with DMA template enable and shared DMA channel CubeMX doesn't generate proper code. In BSP_SD_ReadBlocks_DMA and in BSP_SD_WriteBlocks_DMA miss setting for change DMA direction. Soluti...
lorant124 by Associate III
  • 1248 Views
Resolved! FileX LevelX
I am having trouble integrating LevelX into FileX using the on board eMMC on the STM32H745I-DiSCO eval board. I am using standalone mode (no AzureRTOS). I have successfully implemented FileX to format, write and read the eMMC card in standalone. I am...
dsmail1 by Associate II
  • 2437 Views
UART / SBUS Data Aqcuisition
Hey folks. So for a beginner DIY fixed-wing flight controller, I am trying to incorporate servo values from an external receiver via SBUS [by FrSky (0-> Low, 1-> High; contrary to the standard SBUS by Futaba)] into my software.I found a good amount o...
JGiem1_0-1704717971165.png JGiem1_1-1704718124386.png JGiem1_2-1704718174444.png
JGiem.1 by Associate III
  • 32531 Views
  • 37 replies
  • 15 kudos
Resolved! UCPD + GUI Corruption message
Hello,I have a custom board setup with an STM32G071GBUxN and a TCPP03-M20.I have followed this STM guide for setting it up as a DRP device.It is able to negotiate as a sink with Source only devices, and it is able to communicate over LPUART1 to show ...
NMartin by Associate III
  • 3419 Views
